Replaced by SENR6137. It comes in 3 sections - attached.I don't have SENR6135 but I'm going to try to get hold of a copy.
yeah thats too hot man and the machine would slow down for sure at those tempsI've hit it with a gun once I go past halfway pump is like 184 which is hotter than I'm used to
not sure, could be the normal return noise. it could be related but can't be sure. one way to quickly check is that the return line to the tank should not get super hot because the valve should be shut, but quickest way to eliminate is to take the think out, jam it with a few appropriately sized coins and hopefully it fixes the problem prontoThanks man I will try in the morning, would it cause a loud hiss
184F on the hydraulic oil isn’t anywhere near hot, probably about normal if I’m being honest. Without looking I would say the high temp alarm probably goes off somewhere around 230 or so.I've hit it with a gun once I go past halfway pump is like 184 which is hotter than I'm used to
So pump is 186, going into cooler 167 and leaving cooler 146, oil looks burnedyeah thats too hot man and the machine would slow down for sure at those temps
