Hello all. Just want to say I appreciate all feedback and advice. This is a great resource to have and glad it exists. I’ve definitely learned a lot and saved some money in the past.
The problem: 3rd gear F/R doesn’t work. All other gears work.
Current status: located the shift solenoids and tested that they are energizing (screwdriver trick). They work properly except when I shift to 3rd. In particular, solenoid 3 and 6 are to activate in 3rd and they do not. I am that solenoid 3 does work as it is also used for 2nd gear and when in 2nd gear it’s magnetized and you can hear an audible click (most likely the valve moving).
Im thinking it’s something between the solenoids and the lever shifter in the cab. So I began to tear apart the shift lever but doesn’t seem to be much to repair in terms of a mechanical problem. I was hoping to open up the twist knob on the lever that allows you to select gear 1-4 but no luck yet. Seems there’s a metal pin that holds it together and I’m having difficult removing it. Was hoping once apart there is a contact or broken wire but nothing yet.
Anyone with some suggestions? Thoughts? Prayers?
