ToddOH
Hello all. First post here. Im looking for some input on my 864 with the Deutz BF4M1011. Last week my customer was running when it started billowing smoke out the exhaust. I hauled it back to the shop and pulled the intake tube off the turbo and poked my finger in to check the impeller. Bearings were toast. Replaced the turbo, changed oil and filter, ran it for approx 30 minutes and changed the oil again. Everything seemed well. The next day it went out on rent again. With less than 2 hrs on the clock it started billowing smoke again. It trashed another turbo. This time I checked compression, 425 across the board. I pulled the head anyway and the gasket looked fine. It has never showed a low oil pressure warning so I "assume" the oil pressure is fine. What are your thoughts?
