Hank Hamiltonville Farm
I am trying to remove the rear cylinder that pivots towards the rear of the machine and is the furtherest aft cylinder on the passenger side. It appears the pin goes all the way across to the other side being approximately 2'-3' long. There is a keeper bolt on the driver which I have removed. However there are 3 bolts that are threaded into a nut that is welded onto the tube. I'm not sure if these 3 bolts are "set screws" of some sort, or there to hold a cover plate on. There is no way to turn the bolts. Any ideas on how to remove the pin? I've beat and banged for a couple hours now. Any pro tips would be appreciated
