Marino77
Good day Folks
Hopefully I can get some answers here new to the site .. story goes .. purchased an 86 740 Champion grader..
Invested a fair amount so far.. new main pump/ slave cylinder / clutch as for pressures they are all up to spec however seems the transmission slips.. placing the mould board down machine doesn't want to move let alone cut .. I figure it may be the clutches in the transmission where does a guy start .. Gearco 8400 (29781-720 )Transmission ..
Seeing what's is out there as for a rebuild ..located in B.C trying to save a few dollars re and re are not cheap ...
Thank You
Thank You
