VileMisanthropy
Hello HeEq guys.
I'm having an issue with a stuck cylinder pin, i want to remove the cylinder for rebuild but i can get the pin to press out. The machine is an older 8040 ZoomBoom built in i believe about 1992. Its the front body tilt cylinder on the right hand side and its the upper pin. Now maybe i'm wrong but shouldn't this pin just press out like most? I even built a 20-ton bottle jack press without any luck at all not a budge. The pin appears to have lacked greasing in the past, its a rental machine so its has been quite neglected. heres a couple pictures...
I have though seriously about cutting the cylinder bracket off sending it out and and welding the bracket pieces back on upon return... any suggestions?
