Pipevine
I've got an 8.3 mechanical cummins in a 95 L8000. It sat for about a decade before I got it. Drained the tank, fresh fuel. Replaced the check valve on the back side of the injection pump as it wasn't holding pressure. Everything was great smooth idle, good throttle response etc.....then it just started to sound like it was running out of fuel, giving it some throttle seemed to help for a couple seconds then it died. Took the fuel line from the tank loose at the lift pump and attached a short hose to the lift pump and ran it into a jug of diesel, primed with hand pump, truck started, ran a couple minutes then died like it was out of fuel. Anybody have any ideas?
