773g faster reverse than forward!
Farmereinar
Philadelphia, PA
ahh, so much easier to post on here than skidsteerforums!
i have a 773g that goes much faster in reverse than forward (like 2mph faster), looking under the cab i see that the sticks travel further in reverse than forward
any ideas on what to adjust? thanks!
YouTube - bobcat under cab
RonG
Charter Member
Meriden ct
heavy equipment operator
It is customary to find some earth moving equipment faster in reverse than in forward.Your machine may be designed that way.Ron G
Part sman
usa
Assuming that your steering hardware is tight and you have no pump/motor issues, steering speed can be adjsuted on the steering linkage. The linkage is 2 piece with an adjustable area in the middle. Loosen the bolts in center of linkage and make linkage shorter, this will give you more forward throw. It won't take much adjustment and be sure to adjust opposite side the same amount or machine may veer.
xcmark
Foxboro , Ma.
construction
go back a week or two in the history on this web page ATCO posted some info on common bobcat wear items , I think you will find thats what is wrong.
