Was fixing my drive from all the rain yesterday and my engine oil light started blinking intermittently. I shut it down and open the back door and see hydraulic fluid on the battery. One of the small lines that make a U turn from a block to to the bottom of the lift cylinder had a wear spot in it that was dripping. Just a coincidence I'm sure. Went to clean the connection on the engine oil pressure sensor and the black plastic just broke when I tried to loosen the little nut. Engine oil was full, but does need changing from sitting. Black, but still felt like good viscosity hot. Machines smokes a little after stopping it, but clears in a couple minutes when cold and seconds when hot. Do you think it is the sensor or something else? I do not have the BOSS with code displays.
TIA,
Duke
TIA,
Duke
