Today I ordered the new bolts and fasteners for the suspension which is the eight bolts for the torque rods and respective hardware, and the four bolts with sleeves/hardware for the equalizers. Truck parts supplier has everything on the shelf if I need anything additional. Supposed to snow tonight so may not go any further till next week but planning to bridle to the trailer main frame and roll it over onto it's back with my winch truck. May use "Fred" and his winch so the impact against the ground is not so heavy, but nothing would be hurt regardless. Other thought is to bring the trailer up onto it's side, crib up to keep it from rolling, switch winching positions, and push it over center with the skid steer allowing the winch cable to ease it to the ground. It will be a lot easier to replace the spring hangers with the trailer rolled over. Also going to cut the 4.00"X.750" tension strip free from the lower frame rail as it's starting to rust jack and either replace with new after blasting, or repair the area and reinstall. It's not bad but if not repaired now will get worse quickly. I have new strip purchased for the purpose.
Ran over to the steel supplier and picked up three feet of 2X2 square, solid hot roll and dropped this off at the machine shop to have spindle ends duplicated from the former axle under my portable air compressor that froze a bearing last year destroying the original. I have plenty of 2.5" square .250" wall tube to make the axle tube from as I did with the replacement axle currently installed. However, I want to reinstall the original old steel hubs and wheels with inset mounting and will repurpose this replacement axle under my portable welder to get it more usable for me; then laying serious thought to selling off my old Hobart engine drive machine.
Replacement axle trial built up to get the air compressor mobile again. This is 2.50", .250" wall square tubing and a pair of 7K trailer idler axle spindles and hubs:
By the time it was all welded together, assembled, and aligned under the trailer for proper tracking, it works well. However the bearing caps protrude outside the fender edges and are a genuine shins popper. Photo is prior to final alignment before the new square tube axle retaining bolts, (u-bolts) arrived:
I've pulled this several miles to several jobs since the repairs and it tracks well behind "Krusty".
This is a beam I built up to skid the compressor up onto a trailer after losing the wheel bearing and wheel assembly as I was almost stopped:
I noticed the wheel flopping around in the mirror, got the truck stopped and was backing about seven feet into a field access entrance when the wheel separated from the spindle. I jacked the compressor up, extracted the wheel from underneath and headed to the shop fabricating this skid beam and with this and a couple of welder's "F" clamps clamping the assembly to the axle beam, skidded it up onto the trailer deck with a winch later that evening. Worked pretty well really. Next day, ordered pieces parts to fabricate repairs you see here.
