755d
Mike L
Maine
Self employed field mechanic
Umm, put it in turtle?
Alusium
Keller WA
I have tried both ends of the spectrum in settings. Doesn’t seem to make a difference.
If I touch a function, it’s like the drive goes above full speed as soon as I let off, for a couple seconds, then back to normal.
With one track going extra fast on 40% slope, well , **** rolls downhill…
It’s a cat undercarriage.
Alusium
Keller WA
Thanks for the reply. That’s what I’ve been doing.
Just curious if this is normal?
Mike L
Maine
Ok. So if you go into your display, you should be able to adjust your track settings. I can’t really tell you how to do it off the top of my head but there will be sets of values for each track and you can adjust how aggressive the start and stop, top speed, etc. you’ll have to mess around and find the values that work best for you. Write down all the numbers before you start so worst case you can get back to default settings
Hallback
Aberdeen Wa.
Gyppo tower logger
Yes if I remember right you go into the settings and you can adjust it fairly simply. The start time is somewhere around 60ms and stop time is around 350MS
Alusium
Keller WA
I tried the drive pedal deadband the other day, 25 being lowest, 100 being max. I couldn’t tell a difference. There is another screen for adjustment but it requires a PIN code. Tried the usual suspects but I guess they were wrong. I may have it written down somewhere…
Alusium
Keller WA
Modern was out the other day to work on a tether. They entered the pin and looked at the settings. Apparently the settings were different between the pedals. Seems to have helped. Thanks for the help.
