I have a 753 G bobcat.
I picked it up this summer, and it seems to have ran fine. Since it has gotten colder, (anything lower than 40 f) it has started to cut itself off after it is cranked. The charge pressure warning light comes on, and it throws error codes 05-14 and 05-15. (low charge pressure) I have no hydraulic or hydrostatic control until it gets warm, which requires repeated starts to get there. When I finally do gain control there is a loud click like a solenoid is engaging. If you can get it to crank and stay running, it runs fine and the codes/ warning light goes away. I assume the automatic shutdown is a built in protection, so I am afraid to make a move. I started with a filter change, and even checked the little brass filters under the cab. I have a service manual, and not afraid to get my hands dirty............ Any thoughts? Thank you in advance.
