i dont know yet about the timer need to sort out the harness first but i was tring to remember about the connection.does a double male plug from the harness that the timer plugs into one side with the selenoid plugging into the otherside ring a bell with you or do i have a nother machine in mind?
i have a timer fuse pigtail from a nother machine but this one i 4 times the size ang bolted to left inside of the machine about a foot in and a foot up
Sorry mljohn, I've had a really busy day today, just now getting around to responding to you. There's no doubt a wiring diagram would help you out. I don't have anything on a 743B, I'm thinking your Bobcat dealer should be able to provide one for you. As I said, it's been so long since I've worked on one of those machines, I don't even remember what they had in there.
Partsman pretty much describes the wiring of a basic timer module. The only reason they required a timer module was to remove power from white "pull in" wire of the solenoid after a few seconds. On later Bobcat machines, the ECU controls that function.
But I don't think your wiring is so much an issue at this point, more important, just what do you have for a timer module? You described a module off a different machine (I think) that you said was located on left side of engine compartment, about 4 times the size, about a foot in, and about a foot up. Sounds to me like you might be describing an auxilliary electrical control for machines that don't have the electrical wiring going down the boom to control the electrical on attachments.
Which brings me back to my original question; do you need a shutdown timer module? Have you priced a new one from Bobcat? How much was the parts quote? If it's rather expensive, there are alternative suppliers for solenoid timer modules.
