Jay 68 Case 580CK
First time poster here, but I bought this TLB about 3 weeks ago and have been working on hydraulics lines and cylinder repacking among other things and these forums have been my go to. So thanks in advance!
When I bought it, it started right up. The guys said the engine was rebuilt a couple years ago and the pump was rebuild last year, and the pump looks newly painted. They also said they cleaned the tank.
It's always needed jumping to start, but always fired right up in 60+ deg weather. Last week, it dropped below 40 and it wouldn't start, I chalked it up the cold. I got a block heater and replaced the battery, but still wouldn't start. I had replaced both fuel filters but I had bled it to the pump inlet and ran it for a good 20 minutes after that with no problems at all. Yesterday, I checked the bleeder at the final filter and nothing came out...but I was getting fuel out of the lower filter bowl. Turns out the inlet line to the filters from the tank was clogged, but I could not figured out a good way to clear it. BTW, the tank is completely full. Basically I blew into the line, and of course now fuel gushes out. I refilled the filters, and bled the inlet line to the pump, but still would not start. Now today, batt fully charged, fuel still flowing to the pump, but it won't start...
So I took off (not just cracked) all the lines to the 4 injectors and NO FUEL when cranking. Throttle is at full, fuel stop (manual pull) is disengaged (fully in). I also took the return line off the pump to see if I get any fuel out of there, and NOTHING.
I don't mind pulling the injector pump off and cracking it on the bench, but I hear they are really complex, and more importantly, I'm concerned about messing up the timing and never getting it right again. Since it ran great last week when it was warmer, I also tried heating it with a heat gun on low for a while in case something was iced up (it's right around freezing this week), but no dice. I didn't know about the tank water collector/drain before it got cold, so it's possible that some water worked its way down to the pump.
Any other thoughts or things to try to narrow it down? I saw a recent post, and thepumpguy mentioned pulling the input line and filling to the brim with fluid and cranking the engine to see if it goes down. I haven't tried that yet, but I assume it won't go down since it'd have to be going somewhere and I see no fluid getting to the injector fittings.
Is there a way to see if it's turning if I broke a woodruff key or something on the input shaft (again, not sure why that would happen)? I can't seem to find a parts exploded view either if someone can point me to that.
Pump Is a Roosa Master, DBGFCC 431-27AJ. Date code? is 2100. Serial Number 1515086 MFG No is A-3577A
