I have a bfg m 211 engine. http://www.deutzpartsdirect.com/Documents/deutz-specs/deutz-m2011-construction-specs.pdf
They use the same compression adapters tho.
I was thinking injectors too..
If the nozzles aren't seating properly, the fuel in the lines will leak past the "pintle" and drip onto the piston overnite.. hence the white smoke.. unburnt fuel..
PLUS.. its easy and cheap..lol
ok perfect thanks so much for your time! really appreciate it!Well.. the starter is taking a beating.. the batteries too..
IF its a supply problem.. the fuel is draining back.. the pumps rely on the fuel for lubrication..
No fuel = no lube..
