650K Maint Reset
mg2361
Pennsylvania
Equipment Mechanic
Key on. Press menu. Then next to service. In there you can reset. To disable that function, press and hold menu button for approximately 5 seconds to enter service mode (alarm should beep and service menu should appear). Press next until service is highlighted, press select. Press next to highlight the one you want and press select. One of the choices you should have will be able to disable. Press next to highlight disable and press select.
