644d Brakes Fixed!!!!!!!!!!!!!!!!!!!!!!!!
steve931
Huntsville,AL.
Heavy Equipment Mechanic
The unloader valve was bad,everything in the valve looked OK but a new valve did the trick.Now the brakes work as they should,this thing like to run me crazy.:usa
pjdiesel
maine
excavation
Steve931, how do you like your 644d.i've been looking for a loader for loam and snow looked at a lot of junk. i don't want a detroit or a v8 cummins so i've been looking at newer trojans and john deeres. I have a john deere 540b skidder i've had good luck with that so i've been looking at 544 and 644 b,c and d's. so just wanted to know what you think about them. thanks
LOFAYTX
La Grange, TX.
tractor mechanic
How do the Brakes hold up on the JD 644D? Looks like the same parts as the JD farm tractors use. I have seen the farm tractor ones fail with brake material coming off the pads or breaking loose at the rivet area.
mg2361
Pennsylvania
Equipment Mechanic
LOFAYTX, should have started a new post instead of piggy backing an old one. While there has been issues with the riveted brakes on the 644D's, the brake failure rate also depends on how the machine is used and how well the oil was maintained in the axles. Replacement brakes for those machines do not use rivets anymore. They have bonded pads now.
