Mike Fryer
Hi. I have a 621B. In 1st and 2nd gear the machine will move forward and backwards. But in 3rd and 4th the transmission actually locks up and the machine stops moving immediately as if you have applied emergency brakes. I have switched around the m1 m2 m3 m4 and m5 solenoids and makes no difference. Would the declutch relay or brake system have anything to do with this? I realise that 3rd and 4th gear are on the same shaft in the transmission, could it be a mechanical issue on that shaft?
Any suggestions would be appreciated.
