Thanks! I verified, seemed like something was eating up all the voltage when I tried to start the engine, started checking everything and the starter was fine, computer was swapped and it stayed the same, checked the cable the sends the signal and it was fine as well, I decided to disconnect everything from the system and left the battery connected to the starter with the ground connected to the machine and tried to start it from the starter and it remained the same… checked the cables and the negative cable was not working so I ordered a new one, that hopefully will fix the problem
