590 SM Low high idle
Stanley the dog
Michigan
Once again im back to the play that ive come to get good help and respected answers .The issue im have is on my 590 SM 2002 model is i can only get about 1500-1700 rpm out of it according to the tach ive looked fro the adjustment but have not seen anything (probably because im not looking in the right place)this machine has just under 6000 hours on it and has been owned sense new by a municipality im thinking it maybe governed some how because this machine was also drive on the road a fair amount any input would be appreciated
Coy Lancaster
Arkansas
service tech
Are the foot and hand throttle the same? Check the throttle linkage at the injection pump and disconnect the cable and check the travel of the foot and hand throttle.
Stanley the dog
Michigan
Coy yes the foot and the hand throttle are the same and the hand throttle appears to have move area for more movement before it stops and i will disconnect the cable and check that out tomarow
Thanks for your input
thepumpguysc
Sunny South Carolina
Master Inj.Pump rebuilder
Yes Stan, BEFORE YOU UNHOOK THE LINKAGE..
Get a good base line rpm..w the throttle hooked up..
Just warm it up a little, then mash the pedal to the floor.. record the tach reading..
NOW UNHOOK THE LINKAGE..
& start it up.. grab the throttle, right there at the injection pump and w your hand, rev it till it hits the stop screw and take an rpm reading..
If the 2 readings match, then it’s a simple stop screw adjustment on the pump..
The problem I have with that method is.. MORE THAN LIKELY if your using the engine tach..
ITS OFF AND NOT RELIABLE.!!
Stanley the dog
Michigan
Thank you thepumpguysc i was just getting ready to head to the barn and disconnect the linkage ill do what you said tomorrow after i get home from work and after the machine has warmed up
Thanks again for your input
doghead
NY
Any chance your fuel filters are plugged/frozen? Have you replaced them lately?
Stanley the dog
Michigan
I just tried what you said to try thepumpguy with throttle hooked up with a free spinning engine i get 1900 with the foot throttle i unhooked the linkage and grabbed the linkage connection point on the injection pump and i could run engine up to 2100 and it wasn't at the throttle stop yet i don't like to rev a free spinning engine in fear of breaking something so im guess it a adjustment some place with the throttle linkage but i do know the governor was fighting me as i was trying to rev up the engine at the injection pump
thepumpguysc
Can you get the pump # off the pump.?? Or even a pic & post it??
Depending on the engine conditions, there may be a data tag on the engine.??
THAT WILL tell u the appropriate rpm..
drew15975
What are you guys using for a tach that would be accurate? I have a '04 580SM and on the tach in the cab, my RPM is on the low side according to what the service manual says. 650 idle and 2100ish full - no load is what I read and for the stall tests I'm supposed to have 900 - 1100 and 2350 - 2500. Do you have the 4T-390 engine in yours Stanley the dog?
jsparts
St-Bernardin, Ontario, Canada
Problem is usually at foot pedal on these M. Make sure you get full travel from your foot pedal. check on the firewall, removing rubbermat behind engine helps have more room to work but not necessary!
thepumpguysc
Does it have a stopper bolt under the pedal.??
U can get a hand held tach off the web.. only thing I don’t like about them is the reflective tape they supply.. the glue won’t hold on any painted surface.!
I carry a small bottle of super glue in the pouch w mine..
A drop on the harmonic balancer & wait a minute and your good to go..
Like I said earlier.. the engine tach’s are NOT accurate.!!!
2100 sounds like an Indy Car when your standing next to it.!! Lol
THANK YOU DREW for the specs..
If u have the 4-390.?? The engine data tag will b riveted to the front timing cover.. before u get to the front of the engine.. it’s usually red in color.
(driver side)
U should WRITE DOWN all the info on that tag (take a pic) you’ll need that info for any engine parts you’ may need in the future.!!!
lantraxco
Elsewhen
Diesels are meant to be run at high idle, as long as the governor is working correctly you don't need to worry about running the engine at high revs without load for a while.
Steve Favia
illinois
Retired local 150 Operating Engineer
My 580k tach reads about 500 rpm high ,over the years it started to just creep up ,hopefully some day I’ll figure out how to fix it.
Stanley the dog
Michigan
I checked today and there is a tag with most of the specs on the timing cover with low idle at 950 and high idle at 2200 I played with the foot pedal today and gained some more RPMs now its just shy of 2200 I'm calling that good but did find a 3/16 bolt in the adjustment clevis pin so I know someone's been in there before but its still not hitting the stop on the pump but I'm calling it good till I get a hand held tach owners manual said 2250-2350 for high idle with no load but like I said ill get a hand held tach before I adjust any thing more and there is not a stop bolt under the foot throttle and ill probably adjust to data plate on timing cover not owners manual
I thank you all for the good helpful information
thepumpguysc
Thanks for the update..
We’re happy that your happy..
Let us know how it works out when you get a hh tach..
eBay/Amazon have herds of them cheap..
I did a comparison between a 300.00 tach vs an eBay 25.00 tach.. BOTH were the same.!!
But the obvious was in the construction..
The 300.00 tach was made of hi grade steel and aluminum..& would shoot a laser line 10+ feet..
The 25.00 was ALL plastic & u had to be pretty close to the reflective tape to take a reading..
But other than that, the readings were right on.!! & THATS WHAT MATTERS.
Stanley the dog
Michigan
Im pretty sure i found the problem im thinking it was a bad throttle cable there was a oil leak and oil got into the throttle cable assembly making it gummy and sticky i now how a high idle according to the tach of 2250 and that is under a load of 3rd gear driving down the road but im still taking your suggestion pumpguy i have a hand held tach on order
Thanks to you all
