Eric Martin
hello guys
i am working on a 2008 case 580SM+ backhoe w/powershift trany
the 4wd is not disconnecting, stays in 4wd all the time
I traced the power to the control module in the steering column. i have power from the switch to the control module, but not coming out. and i traced and checked the wires from the control module to the trany, then i put 12volts to that wire on the trany side of the module and that disconnected the 4wd. So it seems that the control module has a short on the 4wd function. Anyone have any thoughts, did i miss anything. That control module costs 10k!!!! from case. and is 20wks out
