gggraham
- Joined
- Feb 13, 2009
- Messages
- 589
- Location
- London Ontario Canada
- Occupation
- Licensed Heavy Duty Equipment Mechanic
A parts customer of ours is having some trouble with a 580SL S2. The machine has 9000 hrs on it, about 3 months ago they had no hydraulics. Trouble was a coupler has wrecked the splines and the splines on the pump. After closer investigation he found the bottom 2 bolts on the harp broken. I told him to replace the engine mounts, the coupler and the pump. I also told him to remove the harp completely and inspect the surfaces for flatness as it was loose. He brought the harp in it was fine, he had pictures of the block it was fine. I told him to install fairly tight and check it for runout. All was fine he said. Installed the harp with new bolts with loctite. Installed a new coupler and pump. Now with less than 200 hrs it has broken the bottom two bolts on the harp and ruined the splines in the coupler, the pump was OK. I’ve fixed plenty of these over the years when I was a mechanic done as I instructed him and never had this occur any thoughts??????
