580k winter starts
Johnnymc
Saranac N.Y.
I have a 1989 case 580k that is new to me. I'm going to need an engine heater to get it started this winter. I'm looking for something I can install myself relatively easily. What do you recomend, a block heater or a coolant heater, or ? Something I can install with limited experience. Thanks in advance.
Coaldust
North of the 60
I would go with a KATS or Zerostart 58mm frost plug style immersion heater. Easy and cheap. Take a close look, it probably already has a heater on it. Amazon.com or NAPA.
I think that model of engine has a spot on the exhaust manifold side of the block for a threaded heater that screws in. But, good luck getting that 17mm plug out. That's the OEM style heater.
Johnnymc
Saranac N.Y.
Ok does this show where it should go ?
Coaldust
North of the 60
I don’t see the threaded port. It’s lower on the block than your pictures show. About 1/2 way between the head and oil pan. C0DBC235-0514-47DE-B65E-2BD2705E7D35.jpeg
Steve Favia
illinois
Retired local 150 Operating Engineer
I have a Oem block heater and oil pan heater on my 580k it was on it when I bought it ,plug them in for a couple of hours and fires right up perfectly,really like it over the either button. I think case still shows the heaters available that’s the way to go.
Johnnymc
Saranac N.Y.
Ok I took some more photos. There is a plug on the side of the oil pan, also one on the housing of the lower radiator hose. I took a few more in case someone can see something I don't. Most of the pictures are on the exhaust side. One or two from the other side. I lost daylight so it was hard to see what I was taking a picture of. Hopefully you can see what I should be looking for
Johnnymc
Saranac N.Y.
A couple more photos
Willie B
Mount Tabor VT
Electrician
Mine came to me with a block heater. If It is away from a power source it usually needs a sniff of ether.
Ether is a powerful drug, it must be used in moderation. I spray at the air intake. By the time it passes through the filter system, the engine gets a very small dose. That is all it should have.
If that doesn't work I start a generator & use a heat gun in the air intake. Open the hood, remove the paper filter & heat the intake with a 1500 watt heat gun.
It is critically essential that two batteries be in excellent condition. Cables get overwhelming, but remember each point where two conductive object touches another, it will oxidize. Where wire (stranded) joins with a terminal it can oxidize. Copper oxide offers resistance. Each pressure connection will oxidize over time & give resistance. New, or well protected connections are needed all the way from battery to starter & back. Most machines use engine block & frame as one way current path. The faces of these connections will oxidize over time. Take the trouble to ensure each metal to metal contact is perfect. In some cases this involves adding a "ground" cable to the starter frame from the battery.
Starters need full voltage.
Batteries are able to give 60% as much power at 0 degrees F they would at 60 degrees F. The health of your batteries is very important.
In two or four battery systems the batteries must be identical.
I've heard extreme practices such as draining oil, storing it inside, removing batteries, storing inside. Even my uncle's system of building a wood fire under the engine to warm it.
Steve Favia
illinois
My 580 only has one battery that I keep on a tender, I also have the button in the cab for either but never cared to use that. I plug both oil pan and block heater in give it a little time maybe one to two hours depending on how cold out,starts up like you just shut it off and starts making heat so I can plow a lot of neighbors driveways for free lol!
Willie B
Mount Tabor VT
Electrician
Heat makes all the difference. Mine is stored in a building with no electricity. I can start a generator to heat it up, or run a very long cord, or park beside the garage.
Johnnymc
Saranac N.Y.
I'm good to go with 2 good batteries and I cleaned all the connectors and ground to the frame and had the starter rebuilt so I should be good there. I tried to start it on a cold morning in the 20°'s and realized i need a heater. Its 35° today and it cranks over once then the starter makes a sound like it has disengaged. I'm not sure if that is another problem, but when its warmer it starts immediately. I wish i could park it indoors but no going to happen this year. So it sounds like i need a heater for the oil pan and another for the block ? I'm sure I can get the oil pan plug out but not sure on the other plug. I still have to find it first. I don't see anything on the exhaust side that looks like a plug I could remove from the block. Would an oil pan heater be enough. I hope to move some snow banks with it this winter.
A block heater is better than an oil pan heater for starting, in my opinion. If the block is warm, then the crank and bearings will be warm enough that the oil won't drag. The oil pan heater is for starting when it's way below zero and the oil won't flow.
You can use a magnetic oil pan heater and one on the block also, but a core plug block heater is the most effective way to warm an engine. You have a factory hole for the heater somewhere, but I can't tell you where it is. Look at the katz site for the engine or model number and it will give you a location and size of the plug they recommend. It will be in the upper part of the block, the water/coolant only circulates around the cylinders, it does not circulate around the crankcase/lower part of the block. Possibly the only place will be in the head on some model? Other option is a circulating" tank style heater, hooked up with heater hoses, but a block heater is better.
Johnnymc
Saranac N.Y.
I can't see where it would go.
JWeir
massachusetts
In the first picture, it goes in place of a freeze plug on the same side as your starter. I installed the block heater Coaldust referenced above. look at Steve Favia's second picture above. Pop out the freeze plug, insert the heater, tighten threads and route the cord and you should be all set. I can get a picture of mine Friday.
