D141486 Switch & a hugh wrench.
Can you mount a small relay somewhere and use a lower rated switch that easier to find?
Well that would be easy to wire if I could get a sealed relay down underneath somehow. But for now I have a lead on the correct switch and will know more later.
I have contacted a foreign place that shows the exact same switch, but they have not responded with prices.
Even if I find the Case switch cheap, I may have to buy a butt-load of them, which I don't need unless several of you need 1 or 2 and want to join the party.
I wonder how much these switches cost in Auckland NZ? I have a son-in-law on the way there now to stay 2 weeks on a vacation with family.
I could send him by the Case place to get me a thumb switch, if the price was cheap enough.
My problem with the control valve at the moment is that I dont have any wrenches big enough for the large solenoid. That thing has a brace underneath that is in the way for almost any kind of tool.
A pipe wrench seem no good, and it would take a powerful long deep well socket.:crazy
My linkage is off at the moment.
Do I need to put the linkage back on to screw off the large solenoid? I think the lever provides the stop, but I don't want to break something off up in the shuttle by twisting the solenoid.
Can you put a pipe wrench on the solenoid housing vs. the bolt area? I don't know if this is a tin can or a piece of cast iron...
I have a local mechanic that is suppose to be coming to help me with this, but he is about the most undependable dude I know; I don't think he likes coming out on service calls.
It could be spring before he shows up.
The dipstick also need a fairly large wrench that I may have but I have not found it yet. It's at least 1.5". I did get the hose clamp off the top side of the dipstick tube.:tong
I don't have any oil in the shuttle at the moment because I am waiting to get these seals replaced.
I do have the pan all back on and sealed up but I hope nothing will rust inside the housing with no oil in it.
Also because of this I have not cranked it in several days to check my new battery box installation etc.
We have had some pretty cool nights here already and it's supposed to be down to about 16 degrees the next 2 nights.
