I'm not any of those guys, but this is a very basic system with a very basic problem. You really need to eliminate all of the simple issues first before anybody can give you any meaningful advice. If the fluid turned milky, then it either has air or water in it. The air would be coming from a leak on the suction side (one of those hoses etc) maybe worsened by a plugged filter or even worse, a collapsed hose. A hydraulic pump that gets air in it won't develop much suction and won't prime itself if it's getting air instead of oil. If the oil is contaminated with water (test by dripping a drop on a surface hot enough to make the oil smoke or burn, if there's water it will sizzle/splatter) then the oil will cavitate worse and the pump will suck worse.
Pressurizing the tank like Tinkerer said will turn those suction lines into pressure lines and hopefully help you narrow down your problem.
It wouldn't hurt to check the filter/bottom of the tank for metal shavings. If the pump went bad, you're going to want to do a lot more work than just swapping out the pump before you run it again.
