Hi GWS!
I have taken the JDB fuel pump off but without its shaft.
I need a puller tool to extract it.
I have 2 questions for you GWS.
-A- you mentioned in the last email a solid flex ring.
is it just one or several of them that have to checked and replaced if damaged!!!!.
-B- I did not pay attention when I removed the pump from its place.
Now I think I have a problem with timing when installation comes.
How to time both engine and pump from scratch !!!!
Thanks!
Hopefully the shaft stayed on the engine. You will need to replace the two cup seals and I think an o-ring seal on the shaft when you put the pump back on the shaft. I made a tool to install the cup seals as the shaft has a few ring groves that make getting the seals on without damaging them tricky. You can usually pick up the little plastic tool at diesel shops.
The flex ring replacement is called an EID. (Elastomer Insert Drive) and can be also gotten from a diesel repair shop. Usually around 30.00 to 40.00 dollars US. They can be found on a number of internet places. The repair kit with the normal flex ring runs about 30.00 or less. Since you have to take the pump apart to fix the flex ring, might as well replace all the seals at this time.
There should be a small plate on the right side, back rear of the engine (bell housing) that covers a small hole. It only has one bolt holding it down. Rotate the engine until you see a timing mark appear (Don't use the starter for this). This will put the engine at TDC for timing the pump. Then slide the pump on the shaft and line up the timing marks in the pump window. The pump can rotate in the bolt holes as they are slotted so the marks on the pump will line up. Line those marks up on the pump before you slide it on the shaft. If you don't find a mark on the flywheel through the small hole then you are going to have to remove the valve cover and the number one fuel injection nozzle to set the engine at TDC.
There are several things you will need to check inside the pump so be sure to look everything over closely.
