donniep31
I am trying to find information on the Case 207D oil pump. I purchase an old 580C to clear property and it starts up pretty much as soon as you touch the key. The oil pressure starts off around 70psi and somewhere after running for a while it drops to 20psi. I have yet to notice if it is gradual or a sharp drop.
The oil has been replaced twice since I've had it with 15w-40 and new filter. Oil level is checked every time I use it and its good every time. Everything is pointing to an issue with the oil pump or relief valve from the information I have read. That being said if I drop the oil pan to inspect the pump, I plan on just replacing it due to the age of the machine.
If anyone has any suggestions on a different path it will be helpful.
Engine runs smooth
No odd noises
Oil pressure responds to throttle movement but will not rise above 25psi once it falls off.
Has an aftermarket gauge that was on the machine when I purchased it
Engine temp 190
Thanks
Engine runs smooth
No odd noises
Engine temp 190
Thanks
