hopeigetitfixed
hi all, new member here very impressed with the knowledge present here.
I recently aquired a case 580B backhoe amongst a few other issues it was lossing power steering fluid from the reservoir but had no obvious major leaks then eventually i noticed the engine oil rising, bingo front seal. For now I have replaced the front seal and filter but i have always been a bit underwhelmed with the power steering performance. It currently has 750/16 front tyres but i have some much better condition 900/16 I wish to fit but there's no way the current power steering could hack it I already have to rev the engine substaintialy to be able to steer it with anything in the bucket.
The steering components are quite well worn so I am intending to doing up the steering cylinders and replace the pump. After looking around a bit its easy enough to find replacement pumps A137187 but I am noticing that in some after market parts lists part number D84179 for a 580C 580D superseds the A137187. I am wondering if this later series pump does in fact fit and if it does is there any advantage such as volume.
