n175h
When I travel in 4th gear, low range my tractor will roll just fine until I put on the brakes. Then it sometimes sounds like all hell is breaking loose inside the transaxle. The tractor shakes and grinds. Let off the brakes, it coasts fine. Sometimes it makes the same noise when starting off in 4th gear. Rattle, grind, shake.
At first I suspected the brakes, but I think it is more serious than that. Brakes work ok in all other gears. It only does it in 4th. I've never used high range, so don't know anything there. It only does it sometimes. A good remedy is to back up a bit in 4th and the noise abates.
1975 580b mechanical shuttle with a floor clutch.
Any ideas where to start looking?
thanks, David
thanks, David
