580b Fanbelt replacement
talltexan6ft7
Hi, do they make a fanbelt for the 580b where you don't have to remove the hydraulic pump? If so, do they last? Thanks!
talltexan6ft7
Thanks! My old belt looks as if it's the original one, don't know how it's staying together, but it is!
Notch8
Ontario
Did mine last fall bit of a pita but wasn’t that bad , clean up the splines and collar and use a nice brushed on layer of never seeze on them when reassembling.
talltexan6ft7
Thanks! Mine looks bad, but is hanging in there. I'm just wondering if I should attempt to replace it before it breaks? Is 186750M2 the correct belt number? Thanks!
Notch8
Ontario
I’m not close to machine rate now but may be able to look for a number later today .
