Glen Weldon
Well, I removed the relief valve and checked it. Either there is an O-ring with a backup ring, or two O-rings or one O-ring with a groove in it. In any case, the valve was sealing. I had to pull it out of it's bore. Wouldn't go back in properly until I lubed it first. I didn't detect any issues.
Still trying to remove the power-beyond connector. The line nut appears to be 1 3/8" or larger. I don't have a wrench that big nor an adjustable that large. I'll be stopping and purchasing a large set up to 2" from Harbor Freight as soon as time permits. In the meantime, I had a leak in the plumbing around the valve stemming from a fitting attached to a valve on the loader connected to a T. Figured while I was in there removing things to get to the power-beyond connector that I'd pull it apart and fix the leak. I'm learning a lot about O-rings because I'm researching replacements for the control valve block. It would seem that the O-ring that is leaking at the loader valve is a size 912 and my local Grainger has them for about $10 plus tax for a pack of 25. Case is calling these by part number 218-5008 as far as I can tell. I'm not sure why Case wouldn't have originally specified these parts by the standard names, unless it's because they didn't want people to know the standard size because they wanted to sell them at inflated prices. Who knows.
If I ever get these O-rings cross-referenced and/or get current correct CASE/IH part numbers, I'm going to publish it in a few forums so other's don't have to go through this pain and suffering! Tomorrow, I'll can probably take a few pictures of what I'm doing since I know y'all LOVE pictures!
Also, is there a way on this forum to see how many (if ANY) folks are reading these posts?
