I am not sure if he did it three times or not, once he made that determination he did not do anything else, except try to sell me an engine and the price get this was not going to include injectors
The machine has 8758 hours and he said the need engines at 6500.......I do not believe he is right if it was a compression issue I would expect low power, blow by additionally you can ether start it and work it for an hour and kill it and it will not start , if low compression I think would start when warmed up....and how would low compression cause the filters to get sucked dry?............anyway we can not get it to start with the injector return line taken loose from tee and the tee is capped so I can not get a true injector only test.......my normal dealer will get a tech out in a day or two, im gonna replace the injectors and see what happens...any other ideas or thoughts
