chris544
Hi guys, new member here. figured id post a question about my 544J loader. machine has around 24,500hrs on her, just recently (the last year or so) ive been having issues with the LCD monitor, would start the loader and it would run good, shift good, but after 5 minutes the screen would flash off, and then continue for the next 30 seconds to come on and off until it would eventually stay off(everything still worked perfect, shifted good etc). if i used the loader for 2 hours and shut it down for 10 minutes and came back again to use it, the screen wouldnt work proper, would be all fuzzy and id sit there for 5 minutes turning the key on and off just to get the screen to boot up proper(so i at least could use it over anything than 1st gear). just yesterday morning i got in it and the screen would not come on at all, it starts but only is able to drive in 1st gear only, im assuming its straight up a monitor issue? thats all i can think of at the moment but any help would be appreciated! thanks!
