Thank you for visiting HeavyEquipmentForums.com! Our objective is to provide industry professionals a place to gather to exchange questions, answers and ideas. We welcome you to register using the "Register" icon at the top of the page.
We'd appreciate any help you can offer in spreading the word of our new site. The more members that join, the bigger resource for all to enjoy.
Thank you!
The cab fan will not turn on. I have 24v at the plug, a solid ground and I can watch the voltage go up in increments on the signal wire as the fan speed knob is increased.
Do you have voltage at the P033A Red wire? If not, then check the F33 blower motor fuse. That would be the center fuse box in the right side compartment under your right window. Also, check the V10 diode. It is next to the center fuse box. It should be to the right of the fuse box. If it is blown, then make and install a jumper. The diode is not needed.
