524H Trans issues
Downers Grove
Of the codes that returned (3) my concern should be The 305 code first? F1658 was repaired when battery was found to be failed due to bad cell. This is where I am at with the machine now.
mg2361
Pennsylvania
Equipment Mechanic
Yes, concentrate on the 305 code. Does the machine move? A faulty output shaft speed sensor or it's wiring can play havoc with your transmissions ability to operate. Did you check the F2 fuse? I think that sensor gets it's supply voltage from that fuse.
  • Like
Reactions: DB2
