farmalls
My backhoe has always had good power and strong hydraulics with no noticeable lag in shifting. I got out to hook up a chain and got back in and it wouldn't move but wheels were free. (Park brake had quit working early this winter and I had to put a bigger fuse in or it blows fuse ) I might have 2 problems . Long story short with all tires in the air they rotate in reverse real slow in 1st and 2nd gear no matter what position FNR lever is in. Set it on the ground and driveshaft will spin in reverse a few turns if I give it some throttle then stops and when I lower rpms again it spins the other direction and stops. (Like it is relieving a slight pressure that has built up ). But no pull down on the engine whatsoever. Any ideas ?
