JJones
Hi
The machine is a Hyundai r80-7 with a 4tnv98 engine with the mp4 fuel pump, The temperature at the machine location is min 24 max 32 , First attempt to start has white smoke coming out of the exhaust and will not start unless they use a flammable spray down the intake, The machine will run fine and stop start the rest of the day. Apparently at one stage it was run out of fuel and this is when it all started.
Could it be the cold start function on the injection pump that works off the coolant temp , but with a low temp of 24 deg I wouldn't think any cold start would be needed, Is there anything else that could go wrong in the injection pump to give these symptoms , Otherwise I'm thinking it could be getting low on compression.
I will be able to look at this machine first hand on Wednesday just hoping to find someone who has come across something similar.
Thanks
Thanks
