CARobo
Long-time reader, first time poster. I've read all the threads about the Case B series tractors and their power shuttle problems. I'm not new to tractors but I purchased my first Case 480b about 6 months ago. This is my first backhoe. Not knowing the service history, I replaced the engine oil & filter, hydraulic oil & filter, power shuttle oil, and transaxle oil. Also had the boom and dipper cylinders repacked due to really bad leaks before ever using the tractor.
The hydraulic oil, transaxle oil, and engine oil were really nasty, however the shuttle/torque tube oil was not nearly as bad. Engine performance and hydraulics performance seem very capable. The power shuttle and torque tube performance was ok but not great. After reading many threads on the B series, I've come to realize this is normal.
This tractor has 8 gear power shuttle with a torque tube. Clutch seems fine. Shifting forward and reverse and into any gears are easy.
This week, I suddenly lost torque in the tractor, similar symptom as what's been reported in many threads where the engine and hydraulics are fine, but if I try to go up a slight incline its nearly impossible. And pushing into a pile of dirt to pick up a load with the FEL is no Bueno. Engine doesn't bog down, real wheels just don't move. Prior to this, I used the backhoe for about 60 hours over the course of a month without any incident.
I do not have the Rockwell transmission that is referenced in the other threads. There is only one drain plug and it's at the rear of the shuttle/torque tube. I also do not have a shuttle filter. I removed the grill in front of the radiator and nothing other than the pump.
The shuttle oil that was in it originally wasn't milky but it appeared to be much thicker than Case TCH or Hy-Tran. Based on viscosity, it looks like 30W or maybe thicker.
When I originally replaced the shuttle oil, I used half TCH and half hy-tran. Field specs on the hy-tran from TSC were almost identical. Talked to a couple of old mechanics at the CASE shop in town and they advised this was ok.
I have read the owners manual and service manual for the 580B and the Case parts website for the 480B.
Any ideas or opinions on what could cause this symptom on the 480B? I don't see a screen or filter inside the torque tube on the Case parts site, so I am not sure what could be clogged. I've read some people have used diesel or paint thinner as a detergent in the power shuttle. I'm interested in trying this to see if it helps before draining the oil again and putting in new TCH only but I don't want to put more, new TCH oil into the unit until I get any remaining dirt or gunk out of the unit.
I have various serial #'s if that helps. Serial # on the frame is 5331306. Serial # on the engine is 2803230. In the shuttle/torque tube itself, there is a "A51800" in raised letters.
Thanks in Advance!
Thanks in Advance!
