if it were mine I would jack it up and make sure the sprocket is good and tight. seal most likely just started to leak with age but if you have a bad bearing you will cause a lot more damage if you don't fix it now. if your sprocket is still good and tight then add a thicker oil to it to slow the leak up. a lot depends on how much you use it. manual would really be nice to have for it.Starting to think this repair may be a little more work than I want to tackle.
