Wow, This is literally the identical problem I'm having. Bought the machine from a "mechanic" that tried diagnosing main boom not coming down. Like Donald I have Tower up/dn, swing, drive and steer but nothing else. On my P1 circuit I have 230 psi at the test port whether I run the gear pump or auxiliary power unit. I have tested all voltages and grounds at the coils, removed and inspected valves for actuation and run though the limited "troubleshooting" page with tests in the JLG 450aj manual. My machine is serial 56xxx with the ford EFI engine. Looking at the valve/coil cartrages, Swing, Upper Lift, Tower, and Telescope all have wrench marks on them. I suspect parts swapping put me in the same boat as Donald. Is there any way to inspect the tip of the valve to see if it is a flow through or not? Pulled the dump valve and proportional flow valve to check operation so I have an Idea of what I'm looking at. Is there another way to check that the valves are correct?
