Dave Neubert
yes the specs I got from Cat said 18 psi the one you got is higherIt was originally built as a DI engine with jacket water aftercooling. Is it still like that.?
It has a oil pressure advanceTechnically---yes, but I'm wondering which advance this has.
Check your messages. I sent you the full 0T spec.yes the specs I got from Cat said 18 psi the one you got is higher
Was working fine then as I was told it started bogging it runs a air compressor should build 350 psi starts bogging at 200 psi with very little smoke timing good governor seems to respondWhat is the whole story? When did this start to happen? And is that why you did all the work to it?
Maybe the gizmo that the flywheel or pto is hooked to has the problem, and is just over loading it?
This is just more info to think about.
Is the governor responding to the load?
Is pump timed correctly?
I thought I remember the old school advance having an occasional slipping problem, its been so long don't know.
Yes engine don't drop any RPM under loadDid the new nozzles bring the boost back to spec?
Who’s this guy? What a jerkI'm wondering if the injectors are atomizing the fuel properly. How does it start?
I don't know what we would do without Vetech & BlueOx, two of the best.Who’s this guy? What a jerk
Never suspected injectors started great sounded good no puffing or miss. the governor on the injection pump was wore out so it needed a rebuild anywayI’ve had Cat nozzles kick my ass like that, in the past. Like Vetech63 mentioned. Hard starting is a great clue. We forget about the easy stuff.
