333E does not move
Kevin Cohrs
Glencoe, MN
Just purchased a very clean 2013 Deere 333E with 1400 hours. Very clean machine but has a hydraulic issue of some sort. Engine starts and runs fine but it does not attempt to move or operate any of the loader functions. Is it possible theres a drive coupler between the engine and hydraulic pump that could have broke? Or maybe an electrical issue not letting it engage any of the hydraulics all together? Looking for any ideas or things to check... Thanks!
muddog1975
knoxville tn
I would check fuses first and then start checking your safety switches, seat, seat belt, if its a cab unit door switch, etc. Keep us posted on what you find.
mg2361
Pennsylvania
Equipment Mechanic
You posted twice.
Serial number?
Like muddog said, operator presence system working properly? Fuses? If it is keyless ignition, is the hydraulic enable switch on (top right button's LED should be lit)?
Kevin Cohrs
Glencoe, MN
Im leaning more towards the drive coupler. All of the lights go off on the left side display and Im able to hit the 2 buttons on the right side for parking brake and unlock. Also showing no active codes. Still never attempts to move at all.
