acegreaser
working on 955L cracked the block at mid counter shaft bearing on the outside left side of block.My question are all 3304 blocks interchangeable. Or does it have to be a PC block only and are the spacer plate blocks the same as the non spacer plate block. Can you use a DI block and will all the parts from a PC fit on it.
