322L low power 3116 engine
BradyHill1
South Carolina
my 95 322L is dying down a little more than i think it should when you operate it. I'm thinking about turning the fuel up a little but was wondering if else has had a problem and maybe it's a screen somewhere about stopped up instead......
Lee-online
In a van, down by the river
There can be alot of reason for this and not always on the engine side, but if it has alot of hour then i would guess the injectors and rack are worn. Some basic troubleshooting should be done, boost, fuel pressure, blow by etc. When i set them up I advance the timing .5mm, adjust the fuel setting to the high side of spec and can turn up the torque screw on the governor if needed.
By just turning up the fuel you are just masking the real problem.
BradyHill1
South Carolina
it's an older machine with a lot of hours on it, I did find in the parts book that there is a strainer in the governor and one that looks like it's under the toolbox, i will check those before i start doing anything major to it...i guess
Per Eriksson
Sweden
Sure sounds like it needs a tune-up.
Does it smoke black when your'e working it and it drops in rpm's?
Blow all fuel lines, change the filter and clean the screen.
Then you could fit a clear hose on the return and check for air in the fuel.
Next is to check fuel pressure.
