pbean
Does anyone know where the 24 to 12volt converter is located on a cat 315Bl?
Another question for you,Behind the panel in the lower rear part of the cab if it has one. the converter is/was an attachment (optional extra) and not all machines were sold with one. Look for an empty 2-pin connector with wires 120 Yellow & 200 Black if you can't locate the converter itself.
If you mean "digital" as in a CD loaded with Adobe pdf files then yes they can be printed to paper should you wish to do so.I see everyone is buying the digital service manuals.
Are you able to print them out on paper?
12volt outlets and the am/fm radio.What would be the function of this converter, aside from powering the cigarette lighter?
When you lower rear part of the cab,do you mean inside cab or out?Behind the panel in the lower rear part of the cab if it has one. the converter is/was an attachment (optional extra) and not all machines were sold with one. Look for an empty 2-pin connector with wires 120 Yellow & 200 Black if you can't locate the converter itself.
Found the 2 prong connector for it.When you lower rear part of the cab,do you mean inside cab or out?
I checked the electrical panel behind the cab and no luck.
Definitely has a converter because it has a fuse for it and a 12 volt radio
It could be. The P/N of the conevrter would depend on what use (radio or accesory) you plan for it.Found the 2 prong connector for it.
Is it as simple as adding a convertor to it?
