wolf44
OK here is how it started. The stick went crazy and went to full extension out on it's own and shut the machine down. Disconnected the lines from the cylinder and looped them back to the tank and moved it back to the shop.
Tried to pull the valve control rod controlling the stick out of the valve housing it was locked in place. after much screwing around finally got it out and found a mangled piece of metal about the size of a pea locking the valve shaft in the main valve body. then we drained the hydraulic tank and pulled all screens and the filters. Found 4 more pea size chunks' in the bottom of the screen. filters look good not any small fine grit in it at all, so far just 5 pea sized chunks. It looks like the stick cylinder has been replaced some time in the past. (clue- maybe ? ) This machine is new to me in the last 3 months. So far I cant see any place these chunks could have come from. Maybe when the cylinder broke last line and they did not get all the crud flushed out and it finally got loose and we have found the problem??
Here is my current plan lap the valve bore where the control rod moves freely again, pull the stick cylinder and take apart and look for more chunks in the cylinder , clean and flush all line and stick back together and see what happens.
Looking for any other suggestions on courses of action, kind flying by the seat of my pants on this one.
One more question any idea what the clearence should be between the valve shaft and housing bore?
Thanks for reading and any help you can give me.
