Tugger2
SN 3XT02093 I went to service the final drives on my 303 cat. The book that is attached to the machine calls for 1 litre of oil in each final drive and warns about causing seal leakage by overfilling. There might have been a quarter litre drained out ,but they show no leakage.
When i roll it around until the drain plug is at the bottom, 6 oclock position,the other plug is right at 12 o'clock. There is one plug in the centre as well. The book shows 3 plugs as well one at 6 o'clock, one at 10 o'clock and one at 1 o'clock listed as drain ,level and fill. Much different than mine.
I couldnt fit a litre of oil into mine with the plugs at 6 and 12 o clock. In fear of over filling ,i rolled the plugs around to 9 o clock and 3 o clock ,letting the level settle there, about a half litre. Has anyone here ran into similar circumstances, Im confused by the manual ,assuming its the correct one by the fact its hooked to a cable behind the seat.
