ben46a
Im not really liking how thats looking either, I was thinking 6 inch minus crusher run. Clay may lead to problems down the line.
Structural fill is ALLWAYS porous....
How do you get in and out of the hole? Whats stopping the dumptruck from backing in?
your trucks have brakes ruebenUMMMM.............brakes maybe..........just guessing....thats how our drivers stop anyway.......:falldownlaugh
hell ya...........and we use them also.Its pretty neat....we push the middle pedal thingy on the floor and SHA-BAM!!!we stop. That option came standard with all of our trucks.
Right now it is just a big rectangular hole in the ground with straight sides.
I'm guessing that when they get everything on grade, they will either lift out the equipment with a forklift, or add some extra dirt to drive everything out and then use the excavator to remove the final dirt. The hole will only be 7 feet deep when they get to final grade.
It seems like overkill to have two dozers working the fill in such a confined area.:beatsme
No, that is not correct, at least around my neck of the woods. I have built many projects with structural fill, 98-100% compaction requirements, with clay type on-site soil that would definetely not be classified as porous. The dirt doc gets a proctor of the fill material and sets the specs for compaction, the fill could be on-site material or borrow pit material.
I have worked with some fat clays that had a very tight moisture tolerance that was a pain in the rear-end to meet compaction.:Banghead However, the compaction specs were met. To import gravel or other porous fill was not an option due to the cost.
I must have mis-understood such a broad statement.
in pic #19 is that the pier footing sticking out the side of the cut?
What kind of load is this footing going to receive (capacity) and what will it be used for (machinery, vibration)? Also in pic #19 is that the pier footing sticking out the side of the cut? How much deeper are you then existing bottom of footings? No shoring or underpinning for existing footings?
The excavation plan seems excellent, but no way I am ever signing off on clay being used under a building or any kind of HD industrial machine.
