Jeffrey Bandel
I wish I would have fixed it when it went to Level One. Maybe it would have regenerated. When it goes to Level 2 your done. Level 3 derates the engine.
Too many people act like you did and hope it will go away if they ignore it. I have news for them - it won’t.I wish I would have fixed it when it went to Level One. Maybe it would have regenerated. When it goes to Level 2 your done. Level 3 derates the engine.
Level 2 you are good if you can fix it quick enough. Level three is service tool required... I shoulda picked up on that one. At least you saved some money fixing the fault yourself.I wish I would have fixed it when it went to Level One. Maybe it would have regenerated. When it goes to Level 2 your done. Level 3 derates the engine.
Most all cats will require the parking brake to be set, no accelerator input, engine coolant temp above 140 degrees, and SCR temp above 600 degrees2013 CAT0299DLGTC00836
It started giving me the E1239-2 code (DPF #1 Conditions not met for Active regeneration). I parked it, put the parking brake on, made sure hydraulics were locked out and low idle. Left it for 20 minutes and came back.
Now I am getting E1239-3.
My question is what conditions need to be met for active regeneration?
