297c hydraulic lift tilt weak
Discussion in 'Compact Track/Multi Terrain Loaders' started by Brandon33, Sep 8, 2021.
  1. Brandon33
    Brandon33 New Member
    Jul 14, 2011
    3
    Wisconsin
    Cat 297c will not pick what it once did. Everything seams to run fine other than the lift and tilt. In load sensing pressure test I get 3100 psi for a second then drops to 2700 psi over 3-4 seconds. When I load it again pressure only gets to 2700 unless I turn off the machine and give it a few minutes then I get the 3100 psi that drops to 2700psi.
    A bad seal or o-ring? Where to look?
    MBT02247
  2. Brandon33
    Jul 14, 2011
    3
    Wisconsin
    279c, sorry had a brain fart
